Volkswagen based the Golf Mk6 on the existing PQ35 platform from the Golf Mk5. This vehicle was debuted at the 2008 Paris Motor Show.
24 Questions View all
Car isn’t starting
Hello, I have a 2011 Volkswagen Golf manual, that I can’t get to start. I don’t think it’s the starter as we’ve tap tested it & it didn’t work. But when we tested the cabled that leads from the battery to the starter it reads as a very low volt. Could someone tell me what and where (&how) to test the next item.
Add a comment
1 Answer
If original, a 12yr old starter can be suspect and tapping may or may not be definitive of starter reliability as no one can predict when starter brushes wear out; the main reason for starter failure after years of reliable use. However, not seeing 12v on the main battery cable to the starter may be the problem. Solve why 12v is missing on the starter end of this cable and you may restore proper function to the starter.
Examine both battery cables for corrosion, powdery deposits on cable ends connected to both battery terminals. A warm solution of water and baking soda will dissolve dried battery acid with a plain water rinse. Bubbling is the reaction to neutralizing sulfuric acid. Do not allow this solution into the battery cells. Ensure connections are tight. Next are ground connections; to chassis and engine block. Last is starter connection from the battery; be sure its secure and not loosely connected. Starters draw the most current from batteries so battery red and main grounds must be clean, free of corrosion and securely connected to allow maximum current flow to the starter.
Add a comment
Add your answer
Klv will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 51
