Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
Apple Pay Doesn't Work
I bought a 2nd hand iPhone XR from someone I knew who had owned it from new. It was a temporary phone while my iPhone 11 was being repaired. Unfortunately, Apple Pay didn't work. I tried a separate NFC tag and still nothing. I ordered a replacement part as per the images shown (not the charging coil, the small little flexi circuit that runs up close to rear-facing camera) and still it does not work. Is there an on-board component that could be faulty?
Add a comment
1 Answer
It sounds like you replaced the wifi flex and not the NFC flex. Check for corrosion or damaged flex cables around the Wireless NFC Charging Flex and connector on the motherboard sometimes the foam around the connector gets in the way of the pins. It's an inexpensive part so I would just replace it. If that doesn't fix it then your NFC IC chip on the motherboard is probably fried. It's very common for the NFC charging flex to get damaged during back glass repairs so I would bet on that being the issue.
Add a comment
Add your answer
Chris Halliwell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 30
All Time: 201
