Teardown information for the Nespresso CitiZ coffee machine. They are available from different brands, e.g. Krups, DeLonghi.
Won’t turn on
Hi, I have a CitiZ and it’s not turning on. Which internal component is likely to be causing the problem? I have an old Magimix I could use some of those parts. Any help would be appreciated. Thank you. Hi, I have a CitiZ and it’s not turning on. Which internal component is likely to be causing the problem? I have an old Magimix I could use some of those parts. Any help would be appreciated. Thank you.
Add a comment
1 Answer
Do you have a model with a dedicated on/off switch on the right side base?
If it's not the power supply/ cable, then it could be the electronics.
In that case, you'd have to check and compare if the PCB of your Magimix (it is a Cititz, too, isn't it?) is identical to your Citiz. As I have seen the order of the connecting cables on the PCB change from model to model.
Add a comment
Add your answer
Georgia will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 22
All Time: 204
