The 5th Generation iPad Air was announced on March 8, 2022. It features the M1 chip and 5G connectivity.
What is the iPad Air 5th Gen battery capacity in mAh?
iPad Air 5th Gen tech specs say the battery is 28.6 Wh, but with no voltage specified I can't calculate the mAh to compare the battery to other devices. Does iFixIt know what the mAh is for the installed battery?
Add a comment
Most Helpful Answer
The Apple A2742 battery is marked 3.8 Volts, 28.93Wh, 7606mAh.
You can read it directly on the battery in the iPad Air (5th Generation) Teardown video at time code 5:36
Score 2
Add a comment
The iPad Air 5th Generation, a device I am familiar with, regarding the battery capacity of the iPad Air 5th Gen, it has a battery capacity of approximately 32.4 watt-hours or 8827 milliampere-hours (mAh).
Add a comment
Add your answer
John Manly will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 34
All Time: 4,551
