How can I repair my damaged LG 31.5 inch LCD 32UN650-W
How can i repair my damaged LG 31.5 inch LCD 32UN650-W?
@smitthakkar okay. what you have here is a broken LCD. There is no repair for it but you have to replace the LCD. Take the back cover off and check the label on the back of the display. That will give you the manufacturer and the exact panel number. Use those numbers to search online for a replacement. These are not easy to find new but you may get a use one. Check places like ebay etc and see if there are any around. You can also try an find the same monitor as yours that is broken, other than the screen. You can then harvest the screen from that.
Repairing a damaged LCD monitor like the LG 32UN650-W can be a complex task and may require technical expertise, tools, and replacement parts. If you're not comfortable with electronics and don't have experience in monitor repair, it's recommended to seek professional assistance from a certified technician. However, if you're inclined to attempt a repair yourself, here are some general steps to consider:
Remember, monitor repair can be intricate and delicate work, especially when dealing with modern LCD panels. If your monitor is under warranty, it's advisable to contact LG's customer support or an authorized service center for assistance, as attempting DIY repairs might void the warranty.
@indonesiat30702 looks like a chatbot! Anyhow, the diagnostics on this one is pretty clear. Check the images. Cool the chatbot a bit and make it relevant :-)
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 32
All Time: 411
6 Comments
@smitthakkar that depends on what is wrong with it. You have to give us more information. What does your monitor not do? What is not working?
by oldturkey03
@oldturkey03 as you can see in images almost half of display is blacked out due to damage.
by Smit Thakkar
@smitthakkar what image? Adding images to an existing question try this to add images to your question
by oldturkey03
@oldturkey03 please check the drive link.
by Smit Thakkar
@smitthakkar it says "No access"
by oldturkey03
Show 1 more comment
