Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
dropped iPhone 4 in water!
yesturday i dropped in iphone in water and immediately took it out..shook off the and out the water and put a vacuum to all the holes..that immediately cleared up the camera window and the phone would turn on....i suctioned out phone for 15 minutes and put in a tupperware container over night filled with rice. phone works fine....can make and hear calls,text,internet etc only problem is when i look at phone you can see it like 3d..certain parts on display are dark when i go to a white or black screen?? when its a colored web page i see it normal..what can i do or whats wrong?
Add a comment
1 Answer
Chosen Solution
I would first read through our electronics water damage wiki. This will help prevent further damage to your phone. Use our guides to help you take the phone apart for cleaning and inspection. If the screen still looks odd after you've cleaned everything you may unfortunately have a damaged screen and will need to replace it. We carry the display assembly here, but hopefully cleaning things up the rest of the way will fix your issue! Good luck.
Score 3
Add a comment
Add your answer
raquel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 12
All Time: 1,552
