Remove a stripped Case Screw?
Well I was replacing the power supply on my ps3 and did not get very far. The screw on the top casing turns but won't come out. Any idea on how to get this screw out? Thanks so much/
That never happened to me with a PS3, but once on a PSP, once on a toy dog and once on an ancient laptop.
I tried to pry it carefully with pliers. To avoid scratching the plastic, I used the plastic pliers they give you with rubber office stamps.
However, in my ill fortune I was kinda lucky, as I found out that on the PSP the plastic thread was stripped, so pulling with the plastic pliers did the trick.
Have you tried also with magnetized screwdrivers? Do the other screws get out fine? On the ancient laptop, for example, I removed all the other screws, and pushed really lightly the top and bottom case, prying them with barely enough strengh to find out if the screw was still holding together. It didn't, but if it did, and if I had used too much strengh on it, I may have damaged the casing.
Also, the good old WD40 may be worth a shot, but I'd put it as a last resort card, and carefully applied. I used it once on a PSP, but then I managed to drop some in the innards, and got me quite a lot of time to clean all the mess.
As Philip said, a stripped screw may be pulled down in different ways according to the stripped part (screw threads on the screw, on the plastic casing or stripped head).
A careful use of plastic pliers may help you assessing the damage, allowing you to see if the screw budges or not.
Another attempt may be using a little bit of Krazy Glue to temporarily "fasten" screw and screwdriver, gaining more torque. However, there's still the risk of putting too much glue and leaving an unsightly blob.
I've also read about drilling the screw using a drill bit smaller than the screw itself, but as PS3 carries really small screws, and it's kind of a costly device, I'd avoid.
There are also specific screw extractors, and they sell them here.
Take a nail and put it under the pull up and then I'll come out
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 9,786
1 Comment
To clarify, is the screw head stripped or do you think the screw threads are stripped? Each will have a different answer for methods of removal.
by Phillip Takahashi
