A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Pc not starting properly
Whenever i try to press the start button of my pc,it dosen't work.Btw It's connected to an UPS.But when i try several times,it works.This problem gives me such headache.Sometimes It's starting, sometimes not...plz gimme proper solutions.
Thanks a ton in advance.❤️‍🩹
Score 1
1 Comment:
Hi @sidratulfarnaz,
What is the make and model number of the motherboard?
by
Add a comment
1 Answer
Dear Sidratul Farnaz,
Firstly, you should determine whether the motherboard is genuine or counterfeit. If it is genuine, try testing your power supply on another desktop computer to ensure it is functioning correctly. Next, check the power input of the motherboard from the beginning to the end of the line. If everything appears to be in order, proceed to check your processor (CPU), RAM, graphics card, and hard drive. When disconnecting these components, be sure to inspect the ports for any potential issues. It is also possible that the problem lies with the port or socket.
Add a comment
Add your answer
Sidratul Farnaz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 80
