Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
Replacing the power flex cable
Can anyone help me please! I need to replace the power flex cable on an Iphone 11. I have followed some of the Ifixit guides to get to this point, but I'm not sure how or what else to remove. I'm guessing that I might have to use some heat to remove the part that is above the power flex cable. Anyone have any experience of this? Thanks in advance.
Score 2
Add a comment
1 Answer
Chosen Solution
You are correct! First, use a Y000 bit driver to remove the screw then you will need a source of heat like a heat gun or hair dryer and an opening pick. Turn the phone over so you’re looking at the Apple logo and heat the top part of the housing for a minute or so (until it’s hot to the touch). Then flip the housing back over and slowly insert the opening pick between the ribbon cable and the housing. Keep working the cable up from the housing slowly working from right to left.
I’ve tried replacing this cable myself on several phones but have found that it’s typically a far better idea to purchase the housing with small parts included. They can’t show the part with Apple logo on it but I assure you, it’s there. When you purchase with the small parts included you just have to move the major components; cameras, logic board, battery but things like the wireless charging coil, the Taptic Engine, the speaker and the power flex cable are already installed.
Thin prying tool for opening electronic devices. Opening picks are essential to open any iPad, tablet, or smartphone sealed with adhesive. Image
Product
iFixit Opening Picks (Set of 6)
$4.95
Score 3
1 Comment:
Thank you so much for taking the time to answer my question so promptly Luke. I haven't actually had time to give this a go yet, but I shall report back on how it goes!! Thanks again :)
by
Add a comment
Add your answer
Neil Phillips will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 37
Past 30 Days: 103
All Time: 3,528
