Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
89 Questions View all
Question Closed
Why is Bluetooth "not found" when keyboard light activates?
Keyboard working fine for over a year. Battery terminal clean, new batteries checked, good power, inserted properly with visible check after removing small plastic cover over strip connector. Keyboard powers up ok with additional evidence of caps lock LED functioning properly. The computer does not find a Bluetooth keyboard connected. Nothing has been spilled, the keys all work fine, the Bluetooth just does not work. Should the electronics be replaced? I can remove by removing one screw and disengaging the strip connector.
Add a comment
1 Answer
Chosen Solution
Go under the Apple to "about this Mac" > more info > Hardware > Bluetooth and see if it shows a card. If not try reseating the card and checking connectors, if this fails replace the unit.
Score 4
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,038
