Redmi Note 12 Pro power button and volume not functioning
My Redmi Note 12's volume and power button doesn't work, I have tried rebooting, going to recovery mode but nothing works, when I drop it, it seems to work for a bit, then dies again.
Add a comment
1 Answer
@oscarbainaymmm Sounds like the power button flex cable is either loose or the connector is slightly corroded.
You can open up the phone, detach the cable, clean the connector with rubbing alcohol and reattach it.
If that doesn't work, you may need to replace the cable.
Add a comment
Add your answer
Oscar Bai (Naymmm) will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 25
All Time: 1,156
