The Bose QuietComfort 35 II (Model Number: 789564-0020) are Bluetooth, noise cancelling headphones designed by Bose. The device comes with a USB charger and a Headphone jack cord, and is compatible with IOS and Android Bluetooth Devices.
I have problems with the cable connector
I have problems when I use it with cable, I tested it with another cable and the problem is the same.
the issue is in the female connector (left side)
When I write to BOSE they offers a replacement, but at the end the price is the same as they are offering in Amazon (with Prime discount)
The headphone is brand new, I don't like to replace it for a new one,
Add a comment
1 Answer
Most Helpful Answer
If they are brand new they should be replaced under warranty.
Score 1
4 Comments:
Sorry, it's not new and it's without warranty.
It's ok, no scratches, no problems.
When I asked Bose they offered an exchange for a new one with a discount, but this discount is less than Bose offers in Amazon Prime day.
They only problem it has is the connection, sometimes is noisy.
I was finding the spare part in the web without success. I don't like the idea to trash it only for a spare part or 20 box or less.
by
@danielodessky it sounds like it could be a bad joint on the connector. If you can, open it up and check the connections for a loose or cold joint. I had a headset with a similar issue and it was a bad joint. Resoldering them all solved the problem.
by
Hi Nigel, I opened it, everything looks ok, no solder problems, it's the connector.
But I found an easier solution. I bought in Amazon an AUX to BT adaptor, I paid $12, I received it a few minutes ago and works great with my computer and TV (I can use the Bose QC35 without cable with my TV!!!)
The next week I will test it in the plane.
I guess is the best solution, of course, the battery life is better with cable without BT, and now I need to control the battery of my headphone and the dongle. But it's better than spend $220 in the replacement.
Thanks!
by
@danielodessky you could try cleaning the connector with some isopropyl alcohol and a cotton bud. Wet it with the alcohol and work it in and out of the connector a few times.
by
Add a comment
Add your answer
Daniel Odessky will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 25
All Time: 357
