The Samsung Galaxy A31 is a mid-range Android device released by Samsung in April 2020. Identifiable by model numbers SM-A315(F, F/DS, G/DS, and G/DSL).
phone doesn't connect to WiFi network with more than 2 m distance.
Hi
My phone doesn't connect to WiFi network with more than 2 m distance. I have to be in the same room as the WiFi.
Another thing, my phone requires to be in close physical contact with the device whenever I'm connected to a device that uses bluetooth like wireless earphones or speaker.
Please help.
Score 1
Add a comment
1 Answer
Chosen Solution
Hi @gregk4338
Seems like there may be a problem with the WiFi/BT antenna (loose/damaged etc - they both use the same one) in the phone. If the antenna/antenna connection appears to be OK it may be a systemboard problem
Here is a composite image taken from a teardown video showing the antenna and also the WiFi/BT troubleshooting flow chart taken from the service manual, that may help.
(click on image)
Score 1
Add a comment
Add your answer
GreG K will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 193
