The Wing is a flagship twist-slate Android smartphone released by LG in 2020. Identifiable by model number F100, followed by variant-specific characters.
How to change the back glass
How to change the back glass?
Add a comment
Chosen Solution
Like @vojtech59738 said any good high heat source will work fine, however a tool like a hot plate is the "proper" way to do it. You can get the "China special" off Amazon or one from iFixIt. As far as the exact way to do it on this exact phone this tear down should help: https://www.youtube.com/watch?v=Ms8UZ46-...
https://www.amazon.com/Soiiw-Microcomput...
CPB Heating Pad for Screen and Battery Replacement
A large heating surface for quickly and efficiently warming and loosening adhesive for screens and back panels on electronic devices. Image
Product
$89.99
Score 2
Add a comment
Most Helpful Answer
Same like most phones today, heat the back glass with hair dryer or somethink like this, till 80°C is totally safe, after remove the glass using some slim plastic, can help also little bit isopropyl alcohol. Clean the frame from old glue and place new back glass, when you get some lower quality part i recomend also use b7000 glue.. Only be carefull with cameras, dont touch the lens etc.
Score 5
Add a comment
Add your answer
Sultan Bin Shaher will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 260
