New Display has no function
Hello everyone,
i have problem since today after i repaired my steam deck. The old display should be replaced with the 512GB variant and I ordered a new one (i.e. the original part) from ifixit.
Unfortunately, after I repaired the Steam Deck, the display remained dark. Of course, I did some research on the internet and tried everything: Efiboot, Restoreboot and simply charging etc.
Unfortunately the display didn't work.
However, I noticed that the backlighting of the display seemed to work and the fan was running.
So I connected the deck to my monitor etc. and lo and behold it boots up normally and the monitor shows an image. I quickly tried all the buttons etc., these also work without any problems.
I therefore assume that something on the display is defective, I have exchanged the display cable again, no success.
So the old display is connected again, this now unfortunately also shows the same error and refuses to function.
What do you think is the problem?
Reconnecting the cables of the display and the motherboard several times didn't help either. Can you possibly help me?
greeting
Felix
Hello @dknmobilro,
sounds really odd to me. I am not a pro concerning Steam Decks, but i will try it anyway. As the deck itself works with an external monitor i suppose the deck is fine. It may be that the old and the new display are defective now.
But what comes in my mind... is possibly the male/female connector on the deck broken?
by BenZ78
Hi BenZ78,
i am in contact with the IFIXIT Support, and they suggested to send pictures of the connectors and a video of the issue.
Regarding the broken connectors I have not seen any signs of broken traces or damage to the connector itself.
by Felix
The iFixit support is a good way to sort any damage of the spare part out. Good luck for your repair!
by BenZ78
Hallo, wurde dein Problem behoben?
Ich habe nämlich genau das gleiche Problem.
by Ivan P
@ivanp19669
Nein, lag am Mainboard. Der Steam Deck ist damit offiziell kaputt :(
Habe ihn bei Ebay verkauft als Defekt...
by Felix
