The Forester was introduced at the Tokyo Motor Show in November 1995 as the Streega concept, and made available for sale February 1997 in Japan, and to the US market in 1998. The Forester was one of the first emerging crossover SUVs.
a/c doesn't work
clutch on a/c doesn't work. How do I fix it?
Add a comment
1 Answer
You first need to be sure why it's not working. Your ac has a low limit switch which means if the freon has leaked the clutch will not engage, if the ac relay ihas gone bad the clutch won't engage there are several other reasons. Most likely one of the two above will be the problem. If possible you need to take it to an ac repair man that you trust.
Add a comment
Add your answer
Robin Ballard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 200
