Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Phone is working fine except the display.
The phone is functioning properly including all the applications, wifi, i tunes but there is no display. There is no damage by water neither did the phone fall recently due to which the problem has occurred. What should i do?
Score -1
1 Comment
display? do you mean the outer glass touch screen or do you mean the part that shows pictures? do the reset and see what happpens.
by
Add a comment
1 Answer
Chosen Solution
The digitizer was probably damaged in the fall. You may need to replace the screen+digitizer assembly.
Prior to that, you can try to hold down the power+home combo to reset the phone.
Score 1
Add a comment
Add your answer
Aakaash will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 234
