A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
How to replace memory
i need to remove the hard drive
Add a comment
1 Answer
While the SSD drive is removable as you can see here in Step 11 in this teardown which is exactly the same as your system MacBook Pro 13" Function Keys Late 2016 Teardown it uses a custom interface, so unless you have a second function key system to plug it into you can’t access the data within it.
Add a comment
Add your answer
zandar10 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 84
