Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
When I squeeze the screen and iPhone togeather the lcd goes white
My digitizer and Lcd are a bit loose from the iphone because the bottom part were the screws hold it in place broke and i lost the screws.
So when i squeeze the iphone a bit to hard the lcd turns white.
Is this a problem with
-The LCD connection
or
-The digitizer connection
or
-something else
Do i need a new LCD???
the top part does hang out of the midframe a bit it never fully locks in place and i cant screw it back in because the two metal rings that are on the digitizer broke off. would i need a new midframe and digitizer?
Score -1
Add a comment
1 Answer
Chosen Solution
If your phone works fine otherwise then no need to replace any parts at this point. They are all functioning except for when you apply pressure! It may be that your midframe, the part that holds the LCD and digitiser isn't quite in the top slots, when you press it is lifting the connections in some way? I'd invest in some screws to secure the display/midframe and hopefully the issue should resolve
Score 3
3 Comments:
by
by
buy a new midframe. 1) it'll keep your screen in nice and tight and stop it falling out if you drop it, 2) with it in snug it should stop the connector lifting and giving the white screen. Hopefully! The only reason to buy a new digitiser is if the touch screen isn't working.The only reason to buy a new LCD is if you have no display. As you haven't mentioned that these 2 parts are faulty then hopefully (!) your problem should just be securing the front display properly. Good luck and let us know if it works.
by
Add a comment
Add your answer
phil will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,759
