My Philips 1.3 screw is badly stripped. How can I remove it?
I damaged badly a Philips 000 screw on the iPhone 7, I need help removing it without any grinding pen etc. Is it possible? I've also tried using super glue but i think I've made it worse because now the bracket under the screw is glued as well (I think so).
This is actually upside down, it's the small bracket that protects one of the screen's cable's under the rear camera.
2 Comments
Try adding pictures. Always helpful to see the issue.
by [deleted]
Will the plate not rotate out the way to disconnect the cable?
by [deleted]
