My freezer not freezing fridge not staying cold enough
My standup kenmore refridgerater freezer not freezing fridge not cool
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 21
Hi @davidklaver,
What is the model number of the refrigerator?
Is the compressor motor running continually trying to drive the temps down or does it stop occasionally?
Can you hear if the evaporator fan inside the freezer compartment is running?
If the compressor is running then the evaporator fan should also be running but the fan will stop when you open a door (either door) and start again when the door is shut. Do not confuse this fan with the condenser fan which is outside the compartments near the compressor and can run regardless of the doors being open or shut.
by jayeff
