Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Damaged Battery, Needs replacement? Safe?
Today I was opening my iPhone 4 up so that I could replace my home button. While trying to remove the battery, I experienced a lot of resistance from the glue.
While prying the battery out, I must have punctured the battery in some way and a puff of smoke came out with a hiss.
Terrified, knowing how violent lipos can get, I ran outside with the phone and it is still sitting there. I am not sure what to do.
Is there a danger of igniting the battery with further tampering or shifting?
Am I in danger if I continue to pry the battery out with a more blunt tool?
Can I still use the battery?
Thanks for the help!
Score -1
Add a comment
1 Answer
Chosen Solution
Austin, I would most certainly NOT reuse the battery. The LiPo reacts with the humidity and does create a fire hazard etc. Remove it from your phone and discard it appropriately for your area. If you are concerned about any further hazard, remove the battery in a safe environment and try to not damage it further. Good Luck and stay safe.
Score 1
Add a comment
Add your answer
Austin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,434
