Handsets of Vtech Doorbell IS7121 Either out of range
Is there a quick code to reset the handsets of the vtech doorbell IS7121? 8 out of 10 handsets are either out of range or no power at the base. I followed the instructions in the user manual, none of which worked.
Score
0
Anybody can help solve this issue?
by Mohd Muaini
Cordless phones means a finite life of rechargeable batteries even when left in their charging cradles. This may be worn out batteries if electronics haven't failed outright.
by F Dryer
Thanks F Dryer for your feedback and comments. I’m looking for a code to reset the handsets of the vtech IS7121-2, I saw such a reset code (s) to reset different handsets of other vtech models. Like *7890# and *331734* or *331734#. None of which worked.
by Mohd Muaini
I'm not familiar with vtech so I'm guessing on a reset; removing the battery to each handset, wait about a minute so memory is erased (unless memory is kept alive with a button cell battery). If you're not concerned about preset memories for phone numbers, removing both batteries (if there's a button cell to retain phone numbers, should result in a hard reset back to factory settings. Your manual should have instructions for setting up the phones as if new.
by F Dryer
I do thank Mr. dryer for his support and help resolving the issue.
I fact, I could rest the handsets by entering the code using the handset keys; as follows:
*331734# and upper left key for intercom or back space. It worked perfectly.
by Mohd Muaini
Show 1 more comment
