Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Voice memo and phone noise
hello my name is Mike,
I am from Germany.
my English is not the best.
But I hope you can help me anyway.
I have an Iphone 3G-S with IOS 5.0.1
It was never Jailbeaked.
When I record a voice memo with the Iphone then rushes the microphone.
The same is also on the phone.
Also the use of the headset does not bring improvement.
I reset the iPhone to factory settings, but without success.
I've replaced the dock connector, but without success.
I replaced the headphone jack with flex cables, but without success.
When I play music, there is no rush.
Only when I play recorded voice notes or phone calls.
Did you have a solution? I'm getting perplexed.
Score -1
1 Comment
your English is better than mine! I'll have a search and see what google throws out but it may be the noise reduction "inductor"?? near the no4 connector. It's a tiny little part about 1mm long. I think this sounds like a problem that a user called James Bond solved and put a good answer to. Maybe you bumped it off in a previous opening?
by
Add a comment
1 Answer
Chosen Solution
Noise during a call
No USB Connection after I broke little SMD element near connector #4!, the part he replaced is labelled noise reduction, i would check this area for damage, also take a look at the connector no.4 pins
Score 2
1 Comment:
I had checked the complete path with my measurement equipment. All Resistors, Coils and Capacitor are in tolerance.
I have the iphone a few days not used.
Then I unlocked the lockscreen and instead of "unlock sound" just came rushing out of the speakers.
I went into the settings, clicked on a Ringtone it was just noise from the speakers. Silently, they heard the sound below the noise.
I then plugged in the headphones, and Try the same again. The headphones can also be heard only noise. I have restarted the Ihpone. But without success.
All connectors are plugged.
The logic board was not measured under stress.
In short:
The microphone, speakers and headphones noise now
I have no more idea :/
Is the Sound Driver "CS42L61A" a QFN or BGA component?
by
Add a comment
Add your answer
Mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 497
