Repair guides and support for Nextbook tablets.
not able to connect to a network
not able to connect to internet or wifi both are working on my other devices Nextbook model NXWIOQC332G Windows 8 THANKS
Add a comment
1 Answer
  • Select the Start  button, start typing cmd, right-click Command Prompt in the list, select Run as Administrator, and then select Yes.
  • At the command prompt, run the following commands in the listed order and then check to see if that fixes your connection problem:
    • Type netsh winsock reset and press Enter.
    • Type netsh int ip reset and press Enter.
    • Type ipconfig /release and press Enter.
    • Type ipconfig /renew and press Enter.
    • Type ipconfig /flushdns and press Enter.
Add a comment
Add your answer
oralia castelo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 116
