Different types of home button?
Hello i live in Sweden and have bought an Spanish iphone the thing is my home button dont work i have changed the Flex cable several times still not working. Then i heard from a friend that there is 2 different kindes of home flex cables is that right? or what can it be?
5 Comments
maybe the problem isn't the home button but the dock connector??? just an idea. I don't believe there are 2 different buttons, there are 2 different Iphone 4/4s, also iphone 4verizon (only in USA I think) and iphone 4 GSM (rest of the world and USA)
by pollytintop
The dock connector worked with a different logicboard, but i will try to change it. if that dosent work eny other ideas?
by Martin
did you buy just the flex without the physical button? does it still spring?
by pollytintop
Only the flex button the physical button i alreadu had, yes it springs.
Can it be the Logicboard?
by Martin
try cleaning the logicboard connection ie from dock onto board, let it dry and reassemble. I'd also thoroughly clean the area the home button sits into and check how the metal plate/home button are lining up on that midframe..maybe it's bent a little so the "springy" bit isn't making contact? maybe it fell off? who knows?
by pollytintop
