Repair Guides for Sony Laptops
415 Questions View all
No LCD backlight/HDMI output not outputting
I have a Sony Vaio (Model name: VGN-FZ290) laptop that no longer has a working backlight, and the HDMI output is no longer functioning. I can not find anywhere on the internet that can help me figure out where the problem is, let alone fix it. It is a machine that is used for AutoCAD purposes, and it is currently running windows 10. The RAM has been upgraded in order to facilitate the engineering programs necessary. I was wondering if there is a way that I can locate the problem location on the motherboard or if there is a newer board that is easier to find that I can replace it with in order to get the machine to full functionality again.
Add a comment
1 Answer
Most Helpful Answer
Hi @jarertstokes,
Have you tried connecting an external monitor to the laptop's vga port or a TV to the laptop's s-video port and check if there is a display from either?
According to the user manual it should have the 3 video output options. Although it seems that the HDMI port is only used if the laptop also has a discrete Nvidia GPU but the other ports can use the Intel GPU (integrated in CPU)
With the laptop on, try shining a torch at an angle close to the screen and check if you can see any images at all. They will be very faint if they are there so trying this in a darkened room may help to see them.
If you can see images then as you have said it is a backlight problem. It could be an inverter power problem on the motherboard, inverter cable or cable connection problem (either end - motherboard or LCD panel) or perhaps the CCFL lamps (backlights) in the LCD panel have failed. Depending on the the make and model number of the LCD panel ( see table, lower right of image below) there are either 1 or 2 CCFL lamps in the panel.
Here's an image of the inverter circuit taken from the motherboard schematic that may help. This is assuming that the motherboard is an MBX-165-MS91 of course.
(click on image)
If you can't see any images then it may be a both a backlight problem and an LVDS cable or cable connection problem (either end - motherboard or LCD panel) or an LCD panel problem.
Given that the HDMI is not working hopefully the reason for this is that it is not a Nvidia GPU hardware problem
Score 1
Add a comment
Add your answer
Jaret Stokes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 29
