New Aura SSD not recognized when installed internally
The SSD randomly died one day and was told I just needed to replace it. After it is installed, whenever I boot the computer (I did Command + R, and Command + Shift + R) it doesn’t show up in Disk Utility, and all I see is the macOS Base System Disk Image Volume which is like 2GB. However when I boot it and hold just Option(Alt) I can see the new SSD and then a drive called Recovery-10.11.6. I even try opening Terminal and using the diskutil list function, and the SSD doesn’t show up there either.
ON THE OTHER HAND - whenever I mount the new SSD to an external dock and connect it to my computer via USB, I am able to run the computer and even sign in (I used this method to install the new MacOS and setup the computer thinking the SSD would work once connected internally, but it didn’t work).
I am at such a loss as I feel like I’ve hit a wall. I would be SO GRATEFUL if someone could help me troubleshoot this issue. Thank you in advance.
