What makes the pully drive teeth to wear?
What makes the pully drive teeth to wear and cause a clicking noise while the washer agitates?
Sprocket wear can be caused by a number of things:
- dirt/debris damaging the teeth
- Improper pulley tension
- Worn chain or belt
- Bad bearings (causing high resistance)
If you make the repair on your washer, I would highly recommend replacing as many parts in the pulley line as possible and giving everything a quick clean and lube.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 372
