Magsafe 2 orange light, new battery not charging (dead)
Computer was totally dead, magsafe always orange. The macbook prior to being completely dead had only worked when plugged in. I originally replaced the battery, because I thought that was the issue. The computer powered on after, but I didn't run any diagnostics because I foolishly assumed I had fixed the problem.
I let the computer die to cycle the battery and discovered that it wouldn't recharge (it did briefly turn back on but was on one percent, powered off and hasn't turned on since). I then replaced the DC-in board, still orange light, no charging. I took out the logic board and saw some corrosion on CD3211A1, which I cleaned. Same issue, computer not charging.
The magsafe is orange when the battery is disconnected. I have tried other chargers with no luck.
Any other diagnostics I can do with a completely dead battery?
