Model A1318 / 32 or 64 GB capacity
299 Questions View all
Worked fine after lcd/digitizer replacement untill this morning.
I replaced a busted lcd & digitizer on an a1318 iPod touch 3g last night... Everything was working beautifully! Left it to charge overnight, and when I got up this morning, it will not power on nor does the computer make a 'connected' sound when plugging in the usb cable. Tried a hard reset to no avail. Any thoughts would be GREATLY appreciated!
Thanks in advance!
~Rob
Score -1
Add a comment
Most Helpful Answer
Hey Rob,
It sounds like one of the connectors probably wasn't connected all the way and came loose while you were using it. Try opening the device back up and checking all of the connections, especially the one that connects to the dock connector ribbon cable.
Hope this helps! Let us know how it goes; good luck!
Score 1
1 Comment:
Thanks for your reply! Tapped it on my knee a couple times & it started working again... Opened it back up (since the tapping isn't a permanent fix) and discovered a broken solder point on the battery connection... Works fine now after fixing the broken contact. Thanks again for your help!
by
Add a comment
Check ur connections
Add a comment
Add your answer
Rob will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 677
