My Ticwatch pro Not charging and not powering
Greetings, my Ticwatch pro isn't charging and not powering as well. Kindly help.
Thanks
Thanks
Hey, Hillary
I'd suggest the obvious approach replacing the battery in your smartwatch. If you've already tried that or it doesn't end up working, make sure your current battery is properly seated and connected.
I have the ticwatch3pro ultra gps
after i was swimming in the pool, i had the same Problem
could IT bei that I have an water damage ?
I had the exact same problem! not sure what to do as I've bought mine 2nd hand
The problem is probably the charger, NOT the watch. On mine one of the two charging pins was pushed in and not making proper contact with the watch. This is a known problem and appears on lots of other internet forums. Advice to change the battery is fatuous.
The Problem is Not with the Pins. They all have a contact. Im checked that with another cable and allthough with my cable on another watch. Both cables are working on the other watch but not in my. So i threw the watch away and bought a Garmin watch
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 78
All Time: 3,282
