TI-84 Plus calculator support.
Arrow Keys don't scroll through previous calculations
The "normal" behavior of the arrow keys is to scroll up and down through previous questions and answers, but my calculator's ones act like the "home" and "end" keys. I've tried multiple factory/default resets and it still doesn't change.
Score 1
Add a comment
Chosen Solution
Press mode and check that you're in Mathprint mode not Classic mode. An OS update to OS 2.55mp might be needed.
You can repeatedly press 2nd then enter to cycle through calculation entries.
Score 1
Add a comment
Most Helpful Answer
Hi
Has the calculator had a battery leak at any point in its life?
If so that may be the cause of the issue
It could also be caused by debris inside the calculator
Here’s a disassembly guide
TI-84 Plus
If you corrosion is found I would recommend cleaning with isopropyl alcohol:-)
Hopefully this helps
Any questions please ask
Score 1
2 Comments:
Never had anything related to a battery leak. It just happened today morning, I was doing math work fine yesterday and it scrolled up and down just fine. The up and down arrow keys actually work, but the problem is their intended function (scrolling up and down) have been replaced by the "home" and "end" behavior.
by
@moony19142
That’s wierd
It might be worth reinstalling the software along side some other things
Here’s a link to doing that
TI-84 Plus CE Recovery Techniques.
by
Add a comment
Add your answer
moony will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 63
All Time: 2,845
