My controler sometimes doesn't respond
Here is my problem, while i'm playing my games normaly, then the character gets moving by it self and the controler don't respond until gets to normal, i try to reset my controler but works fine and it happens again, I seach in internet and I discover that the main problem is not the controler is the console, I teardown where is the motherbord and I found the problem, the Wifi-bluethoot connector to the motherbord is broken (see pictures) so is there a way to fix this tiny connector or I have to replace the hole motherbord? what is your answer?
Also I want to let you know the socket from that board is missing, is there a way to get a new socket from internet? if is possible where to find it, what is call and if there is a solution.
4 Comments
Why is the socket missing? If it's not on the board, wouldn't it be attached to the plug? Grab from a donor if you can. While I've never seen the usual parts outlets have these, I'm sure they're a semi-standard part. I'd search for something like 3 mm coaxial socket or whatever they measure.
by Dan Sayers
I don't know, I purchase it on internet, then ithad problems so I send it to a tecnical repair, then it work just fine.
but before that i play games as normal and then the character moves by it self, try to move and press all the buttoms but it doesn't respond and then finally respond, later again and again. Before and after fixing has the same problem until when I open the console cover I notice it has the missing socket and I don't know why?
by Izac
https://newbeedrone.com/products/newbeed...
Is this theone are you talking about?
by Izac
It name is call SMT antena connector
https://www.aliexpress.us/item/325680117...
or this one?
by Izac
