Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1954 Questions View all
The ribbon number 7 dont "snap"
my iphone 3gs has no wireless signal, i discovered that the ribbon number 7 was loose and dont "snap" back because both sides looks bad or a little broken.... my question is:
if a change the dock assembly my iphone works again???
Comments:
only if you can make a good contact with both sides of the connector. you may need to find someone who can replace the bent part. try hector truong on here or google his name for his blog.
by
thanks polly.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Mel, post a macro shot of the connector if you can. Sometimes you can bend it back to make it snap again, dont force it though, if you do then it will certainly need replacing.
Add a comment
Add your answer
mel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 465
