Front case clip bent/spoil,due to pulling the back plate with screw
Hi guys,I wanted to upgrade the ssd on my steam deck and when I was removing the screw on the backplate of the steam deck,one screw became stripped and unable to be remove.Out of frustration(I was doing it on midnight),I continued to pry open the backplate and then forcefully pull it out.I was able to swap the SSD when I pulled the backplate out but the clip of the front plate was spoiled or bent.The backplate can be replaced easily but not the front plate.What would you guys suggest me to do???
The issue is I could not completely cover the steam deck as the side where the clip is spoil cannot be cliped even though it can be screwed.Unfortunately,when I want to remove my sd card from the deck I couldn’t do it normally,probably because the cover is not fully closed
