A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Dead backlight after replacing key
I replace my wife's C key on her 2017 Macbook Pro, because it was hanging by only one of the retention clips. After replacing all the components of the key, the backlight no longer works. Can this be corrected or has it been permanently damaged?
Add a comment
1 Answer
Ouch! Did you poke to deep and hard? There is a thin sheet which holds the tiny LEDs that light up the keyboard. You either hit the LED near the key or you punctured the foil trace which powers them
Replacing it is a sizable job! Here’s the part A1708 Keyboard Backlight For Macbook Pro Retina 13" 2016 2017 A1708 Keyboard Backlight For Macbook Pro Retina 13" 2016 2017
We don’t have a guide to get you down to it, but give this a view MacBook Pro 13" Function Keys Late 2016 Teardown all you need to do is get the logic board out as well as the fans and the Antenna bar which can be tricky if you don’t use the correct driver
Maybe it’s best to leave things alone ☹️
Add a comment
Add your answer
Alex Brunner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 77
