Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
473 Questions View all
Replacement display touchscreen not working in one area
After replacing the display everything works fine except the touchscreen on the 0 number area where you enter the passcode.
Old screen works fine except for the cracks.
Now while repairing i didnt do anything wrong or had any problems whatsoever.
My concern is if i could pissibly damage it while removing the blue sticker/protection on the backside of the display?
Since i need to return the display im scared they will mark it as user/installation error
Add a comment
1 Answer
Hello Roberto,
therefore, before installation, the operation of the screen is checked, because Chinese duds are everywhere.
anyway, it doesn't necessarily mean damage. You may have misplaced the touch function connector. Take the screen out of the housing again, unscrew the insulators, disconnect the battery, then the screen straps (x2+x1). Check if something has fallen into the port, which sometimes happens. Insert both screen tapes, battery and check operation. If it's good, disconnect the battery again, plug in the FaceTime sensor strip, plug in the battery, tighten the insulators, insert and latch the screen, tighten the screen screws. The End. However, if the test fails, the screen may have been damaged prior to installation or was damaged during installation. Removing the protective film from the inside of the screen could not damage it - it is a transport and protective film for the time of factory tests against mechanical damage. If you damaged the screen, then look for the touch function connector or tape continuity in the area. Otherwise, if it hasn't been broken, it's unlikely to be damaged.
1 Comment:
Hi, thank you for your answer. I did try connecting it again and checked the cables. Cables look perfectly fine
I have returned the original screen and touchscreen works, so the port is working.
I will try to get a replacement
by
Add a comment
Add your answer
Roberto Mihaljenovic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 31
