Televisions made by the Chinese multinational electronics company, TCL.
How to remove bezel
How do you remove bezel from 65r615 TCL tv?
I'm having problems removing the top half of the backing, there are no screws and it looks like it's a glass that is glued.
Thanks for any help
2 Comments
J S you got the back off? Post some pictures with your question of what you got going on there Adding images to an existing question
by
as I understand it, once all screws are out the back should lift off. If it does not
lift off, then heat it?
by
Add a comment
1 Answer
Chosen Solution
Sorry it took so long to get back.
I was finally able to get the back off, quite easy actually.
The top half of the back is held on by adhesive strips. I used a hair drier to soften the glue on strips and slowly pull off the back.
It then exposed the remaining screws that had to be taken out.
Score 1
2 Comments:
It would be greatly appreciated if you could share some pictures of the bezel less TVs (may be google drive link or external link to share the pics) . I am looking for 100% bezel free TVs so I can tile them to achieve a larger screen size.
by
I’m looking to do this as well. Would be nice to use four 65 inch oled tv’s but don’t want to risk ruining the tv’s taking off the bezels.
by
Add a comment
Add your answer
J S will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 46
All Time: 1,630
