accidentally Plugged my K-supreme on 220v outlet
Hello I accidentally plugged my Keurig machine to 220v outlet, I opened it and saw MOV and 10ohms resistor beside it was burned. I ordered replacement part (MOV 14D241k & 10ohms) now when I re-solder it and tested it the resistor (10ohms) keeps on exploding, I Got 9pcs left. can anyone can help me what should I check? I only know basic knowledge on electronics.
Untouched Board (Right after disassembly)
Update (02/07/2023)
those black spots on the back caused my a resistor blew mounted on the back of the board.
when I test the newly attached components I only plugged the 3 terminals bellow BLK,BLK, WHTE
and the 10ohm resistor keeps on blowing
Update (02/22/2023)
Is this board compatible to the machine particularly on the display Board? It has different part number but it is for Keurig k supreme.
1 Comment
Super User, Start by taking som good quality and up close pictures (use good lighting, high F-stop, long shutter speed and a tripod to get the best pictures), of the board(s) in your machine, both sides. Then update your question and add those images. Adding images to existing questions, this will let us see what you see
by Geir Ove Andersen
