Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
34 Questions View all
Moved screen, it si a bit offset
Hello guys,
a few days ago, I accidentally dropped my mac. And somehow the mac's screen moved a little and it's offset. Is there any way to fix it? Like just by unscrewing the screws and moving the screen back?
But everything else looks and works just fine.
As you can see in the pictures, one side is moved back, the other is where it's supposed to be.
It's also moved a bit on the sides.
Thanks for help!
Add a comment
1 Answer
While there is a little play in the displays mounting it’s hard to tell with the limited images if that would be enough to correct this. Review this guide MacBook Pro 14" 2021 Screen Replacement basically you will need to follow it for the first part to disconnect the battery getting through to Step 16. Then jumping down to Step 32 to loosen the hinge screws so you can shift the display.
Do inspect the cables as they can get damaged from the shift.
Add a comment
Add your answer
ondrej.hobza will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 34
