Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
Identifying where which screws go where.
I recently purchased an iPhone 4 (Verizon) from someone who tried to replace the front screen. They decided it was more than they bargained for after they stripped most of the internal screws and put the phone back together.
When I opened it I noticed that the screws were either stripped or missing so I ordered replacement screws.
Because there are so many screws of different sizes etc. I couldn't figure out where some of them were suppose to go.
I segregated the screws in hopes of identifying by deduction what size the screws were as compared to the repair manual since it tells you what screws to remove and their size. However. I found this pretty hard to determine in some cases.
Is there a diagram or something that I can use to help with this issue?
Additionally, I'm not sure if the previous owner damaged the antennaes when he put it back together.
The phone has a very week wifi signal and 3G signal. How can I tell if they need replacing?
Add a comment
1 Answer
Chosen Solution
Have a look at THIS ANSWER - it may help you with the screws and locations.
The phone will not work too well if not assembled correctly - so yo may resolve the weak signal issue just by proper assembly
Score -1
Add a comment
Add your answer
Wayne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 7,344
