Repair guides for Microsoft's Surface Laptop Go, released in October of 2020.
7 Questions View all
Left my laptop overnight in cold car
Hi, I left my Microsoft surface go in the car overnight (11 hours) at about 0 degrees C (I think), and it won’t turn on… It was really cold to touch but now it’s heating up but won’t turn on. Can I fix it at home ? Or will it be broken inside ?
5 Comments
Hi,
Does it indicate that the battery is charging when the charger is connected to the laptop?
by
@jayeff hi thanks for your answer, I haven’t tried plugging it in since I didn’t want to break it if there’s moisture inside, but will try now
by
@Penny Heslop-Pemberton
Hopefully it won't take too long but allow it to fully charge and then try turning it on, with the charger still plugged in.
by
I would personally leave it in the house for 24 hours to gradually warm back up. It's not really the laptop, more the chemicals in the battery.
by
Add a comment
1 Answer
Most Helpful Answer
Penny, as @jayeff has said, let it charge, then try turning it on in a little while. The important thing about electronics that has been left in a cold (but otherwise dry) environment, is to let it slowly acclimatise (as in warm back up to room temperature) before doing anything. Blasting it with heat and such, is a sure fire way to let condensation form, and cause liquid damage to the boards inside.
Score 1
Add a comment
Add your answer
Penny Heslop-Pemberton will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 64
All Time: 2,492
