This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
Top Screen Copper Strip/Tape?
I replaced both screens on my DS Lite because they had yellowed and noticed the replacement top screen didn't have something the original had. Circled in the picture below (of the original screens), it looks like a copper strip or copper tape that's soldered to the ribbon. What is this and is it needed?
My DS Lite won't turn on after replacing the screens but I'm confident it's a blown fuse due to not covering the back of the bottom screen with electrical tape first. But it's also possible this mystery copper could be related since I don't know what it is, so I'd like to focus on that.
Add a comment
1 Answer
Most Helpful Answer
The strip of copper tape is a grounding strap, probably helps with dissipating static charges. I wouldn't worry too much about the lack of one on your replacement screen; it will work without it and doesn't make it more susceptible to failure. You see those on trackpads quite frequently.
You are correct in assuming that strap is not related to the failure of your DS to power on.
Score 1
Add a comment
Add your answer
Fliggle_Slaps will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 613
