Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
67 Questions View all
Will Touch ID button work if Touch Bar is replaced by newer Touch Bar?
My MacBook Pro m1 2020’s Touch Bar has a hairline damage happened. Only left half of my Touch Bar is functioning properly. Right half of my touch bar along with my touch id button is not working now. My question is, if I get my Touch Bar replaced with newer one, will my existing Touch ID button work with newer Touch Bar
Add a comment
1 Answer
Chosen Solution
if you have good replacement parts, it should be fine
PLEASE NOTE: touch id will no longer work due to it being paired to the logic board and can't even be replaced with a touch id sensors for another macbook pro!
MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Replacement
guide is above and below is touch bar and touch id button
MacBook Pro 13" (A2338, Late 2020) 3.2 GHz Logic Board with Paired Touch ID Sensor
https://www.mobilesentrix.com/touch-bar-...
good luck!
MacBook Pro 13" (A2338, Late 2020) 3.2 GHz Logic Board with Paired Touch ID Sensor Image
Product
$699.99
Score 1
1 Comment:
Venkata & @timtomissus - To clarify! The TouchID sensor is part of the Power Button not the TouchBar unit. Replacing the TouchBar won’t disrupt the TouchID. You do need to be careful! Removing the Power Button/TouchID before you remove the TouchBar. The ribbon cable is easy to damage so go slow and carefully.
Reference this guide Step 21 MacBook Pro 13" Touch Bar 2019 Logic board Replacement and after removing the logic board gain access to the screw which holds it.
by
Add a comment
Add your answer
Venkata Krishna Chaitanya Desu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 34
