Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
113 Questions View all
Can you replace the touch bar using the mid 2020 directions?
I'm going to attempt to replace the touch bar on a late mbp 13" A2338. The touch bar link for the mid 2020 mbp states that it is also compatible with the late 2020 mbp as well. Do you know if there are major differences in the processes?
Add a comment
1 Answer
They use the same touch bar. Make sure you are also using A2289 model, because A2251 touchbar is different
Add a comment
Add your answer
Joel Berger will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 12
All Time: 61
