PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Water damaged PS4 controller
My controller ended up in the water for about 5 second, I took it out, dismantled straight away and dried, cleaned with isopropyl, put everything together and it works perfectly fine but ONLY when on charge, when i disconnect from charging the light goes off straight away. I have another controller that I took apart and swap the battery and back panel and still the same issue, when I put battery and back panel from flooded controller to the working one everything works, no issues. Tried resting controller with pressing the reset button for 10 second but nothing changed, is it beyond repair? what should I do next?
Add a comment
1 Answer
Hey, Dawid
There is likely an issue with some cables within the controller, so I don't know how to proceed with repairs. However, I would suggest trying different cables/wiring from the battery.
1 Comment:
there isn't really that much cables to try
by
Add a comment
Add your answer
Dawid will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 197
