The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
Disks won't spin after replacing the laser
I just replaced the laser in an old gc, and it's moving, but the disk isn't spinning up. Not sure if that was already happening or if it's a new problem though. What can I try now?
Update: took it apart again to check for that solder ball, and now the disc spins, but the laser doesn't turn on
2 Comments
@sadmango, Did you remove the solder ball all lasers are supposed to be shipped with to make it transport safe?
by
no, i didn't know there was one
by
Add a comment
Most Helpful Answer
Go back over the connections you disconnected and make sure they are all connected correctly.
Score 1
Add a comment
Did you get rid of the solder that you need to take off?
Score 1
3 Comments:
I don't think there was any. I'll add a pic in case it's just me being dumb
by
@sadmango Ok, Thanks
by
@sadmango That cable looks burnt?
by
Add a comment
Add your answer
just some mango will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 213
