Why will my phone charge or turn on?
I have had i plugged it in for a couple hours pressed buttons and it won't turn on or charge.
Hi @smallls
Have you tried using another known working, compatible charger or charger cable or connected it to the USB port of a computer to see f it starts to charge and then turns on?
Use a strong light and a magnifying glass and check that the charge port enclosure is not blocked with lint etc. which may prevent a good electrical connection to the charger cable. If it is do not use a metal pin to try and clear it as you may damage the pins inthe port. Use a vacuum cleaner to try and clear it.
If it still doesn't indicate that it is charging it may be a loose or faulty USB charge port. Here's the HTC One M9 Headphone Jack/Micro USB Board Replacement guide that may help so that you can check if it is loose and just needs resoldering or if it may need replacing. Replacements are available online. Just search for HTC One M9 Headphone Jack/Micro USB Board to find suppliers that suit you bets.
The phone is prehistoric in mobile terms. First thing I would do is replace the battery.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 106
