Comprehensive repair manuals on all portable tablet computers by Apple. Repairs are likely to require heat and careful prying.
5765 Questions View all
Touch screen no longer turns and adjusts when turned
when I turn the device the screen does not turn
Add a comment
1 Answer
Chosen Solution
Monica, I suppose it is possible that your rotation lock is turned on. Check on here and see if you can turn it back on. You should also get there by double-clicking the home button. that should bring up a menu bar on the bottom of the screen. Slide the menu from left to right. The furthest icon on the left has a lock symbol, tap it and it should turn your rotation lock on/off. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Monica will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 400
